Configure RIPng Globally
Configure RIPng parameters on the router so you can control RIPng behavior on the system.
You can configure RIPng only on a global router. You cannot configure RIPng on a VRF instance.
    enable
    configure terminal
  2. Enable RIPng globally:
    router rip ipv6–enable
